[gdal-dev] netCDF with VIRTUALIO?
Lucian Plesea LPlesea at esri.com
Mon Aug 1 12:55:39 PDT 2016
Thanks, I'll give it a try!
Lucian
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Monday, August 01, 2016 12:48 PM
To: gdal-dev at lists.osgeo.org
Cc: Lucian Plesea
Subject: Re: [gdal-dev] netCDF with VIRTUALIO?
On Monday 01 August 2016 19:23:50 Lucian Plesea wrote:
> The driver itself doesn't seem to have support, but before I write it
> off, is there a way to get netCDF to work with virtualIO?
Lucian,
On Linux, you can use the vsipreload hack :
https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.osgeo.org_pipermail_gdal-2Ddev_2013-2DMay_036359.html&d=CwICAg&c=n6-cguzQvX_tUIrZOS_4Og&r=ZN_tL2S6ZCPdMt_gpID_yQ&m=8TR390X7glmDIlHMaRoHnpgdgDe-mltjsG8P3Jk3Fso&s=6ooByMMBQLteINs84mo6C5cybh_DCBrpHPFW8cPtcMg&e=
But I'm not sure it is really possible to do a clean virtualIO implementation with netCDF since last time I checked it didn't provide an abstraction for file operations that could have user implementations.
Even
Spatialys - Geospatial professional services https://urldefense.proofpoint.com/v2/url?u=http-3A__www.spatialys.com&d=CwICAg&c=n6-cguzQvX_tUIrZOS_4Og&r=ZN_tL2S6ZCPdMt_gpID_yQ&m=8TR390X7glmDIlHMaRoHnpgdgDe-mltjsG8P3Jk3Fso&s=a2E7uUlgSEpt3DjDbrupca-Xr08kigG3CQ_tlmQrjPA&e=
