[gdal-dev] DPI for printing in geospatial PDF
John W. Glendening glendening at drjack.net
Tue Aug 2 10:56:10 PDT 2016
On Tue, 2016-08-02 at 09:37 +0200, Even Rouault wrote:
> Your use case makes sense. The current behaviour is such that when reading,
> the GDAL PDF driver can retrieve the original size in pixels.
> I've just committed an improvement that will enable the user to select which
> behaviour he wants.
Glad to hear that the written GDAL fiile will be more usable by those
wanting
to print same.  Thanks for your effort on this, as well as GDAL in
general which
I extensively use in the maps I create for hikers.
Thanks also for the background behind why someone would want a
non-default UserUnit written to their PDF file.
Jack
bigsurtrailmap.net
