[gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
Mateusz Loskot
mateusz at loskot.net
Thu Aug 4 07:07:25 PDT 2016
On 4 August 2016 at 15:41, Ivan Lucena <lucena_ivan at hotmail.com> wrote:
> Hi Mateusz,
> I far as I know the project generated by makegdal_gen.bat does not work with newer version of VS.
> It used to be the case that we can import the project to newer version of VS but I think that MS dropped the support for that feature.
> Have one of you manage to load the generated .vcproj into VS > 2010? I would like to know how to do that!
Ivan,
1. makegdal_gen 10.00 32 > makegdal10.vcproj
2. Launch VS2015
3. File > Open > Project/Solution...
4. Select makegdal10.vcproj
5. Accept to upgrade
I can confirm it works for me.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
