[gdal-dev] ogrinfo not a C callable function?
Paul Meems
bontepaarden at gmail.com
Thu Aug 4 07:31:05 PDT 2016
Hi Even,
Thanks for the clarification.
We will update our code accordingly.
Regards,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
*The MapWindow GIS project has moved to GitHub
<https://github.com/MapWindow>!*
Download the latest MapWinGIS mapping engine.
<https://github.com/MapWindow/MapWinGIS/releases>
Download the latest MapWindow 5 open source desktop application.
<https://github.com/MapWindow/MapWindow5/releases>
2016-08-04 13:41 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> On Thursday 04 August 2016 13:25:19 Paul Meems wrote:
> > Hi,
> > When I look at RFC 59.1 (
> > https://trac.osgeo.org/gdal/wiki/rfc59.1_utilities_as_a_library) I see
> > gdalinfo,exe, ogr2ogr.exe are all C callable functions now.
> > But I don't see ogrinfo?
> > Do I understand it right that ogrinfo.exe is not a C callable function?
> Yes
> > If so is there a specific reason for that or will it be implemented in
> the
> > near future?
> The most uses of ogrinfo output features in the console with the
> DumpFeature()
> call, which doesn't make sense for a library function, so a librarified
> version
> would just address the metadata part. Which you can easily access through
> the
> C/C++ API already.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160804/e00b158a/attachment-0001.html>
