[gdal-dev] Error Compiling GDAL with ESRI FileGeodatabase Support On Ubuntu 16.04
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Aug 4 13:41:59 PDT 2016
On 2016-08-04 5:24 PM, Andrew Joseph wrote:
> I'm not able to compile GDAL with the ESRI FileGeodatabase driver (needed for
> write support) on Ubuntu 16.04 with Docker (current LTS) I'm using the the
> travis.yml of the 2.1_gcc5.2_sanitize coverage branch as a guide since that
> seems to be the closest environment to 16.04.
I try to maintain my notes on compiling the FileGDB driver on the GDAL
wiki at https://trac.osgeo.org/gdal/wiki/FileGDB  It would be great if
you could add to those notes, by adding a section for Docker steps
directly in the wiki.  Thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
