[gdal-dev] Feasibility of expanding VRT schema to allow users to specify X/Y dimension for HDF data?
Even Rouault
even.rouault at spatialys.com
Thu Aug 4 15:32:03 PDT 2016
On Thursday 04 August 2016 16:31:25 H. Joe Lee wrote:
> Hi,
> My name is Joe Lee and I'm very interested in improving GDAL's
> capability to access NASA HDF4/HDF5 data so that users can work with
> HDF easily through GDAL. For example, my goal is to allow users to
> translate any HDF data into GeoTIFF via gdal_translate.
> I've worked with diverse NASA HDF products and provided solution for
> visualizing data correctly through Python/MATLAB/IDL/NCL [1] and I
> know that many products, other than HDF-EOS, may not work well with
> GDAL because HDF is flexible and NASA data producers do not
> necessarily follow the conventions that GDAL uses.
> By default, GDAL HDF4/HDF5 driver uses the following convention for
> unknown products.
> For HDF4 (frmts/hdf4/hdf4imagedataset.cpp):
> // Search for the starting "X" and "Y" in the names or take
> // the last two dimensions as X and Y sizes
> iXDim = nDimCount - 1;
> iYDim = nDimCount - 2;
> For HDF5 (frmts/hdf5/hdf5imagedataset.cpp):
> int GetYIndex() const { return IsComplexCSKL1A() ? 0 : ndims - 2; }
> int GetXIndex() const { return IsComplexCSKL1A() ? 1 : ndims - 1; }
> The above code works well as long as Unknown HDF product follows the
> above convention. However, in reality, HDF data can have an arbitrary
> order in terms of Band, X and Y dimension like this:
> dset4D[XDim=360][YDim=180][Band1=2][Band2=3]
> dimindex: 0 1 2 3
> Since ndims=4, ndims-2 becomes 2 and ndims-1=3. In such case, GDAL
> generates 360x180 bands of 2x3 images, instead of the desired 2x3
> bands of 360x180 images.
> Thus, I'm wondering if GDAL can expand VRT schema so that VRT allows
> users to specify the correct dimension index because specifying
> dimension order for each different NASA product in [1] is
> impractical. For example, I'd like suggest a new tag like
> "SourceDimension" like below:
> <VRTRasterBand dataType="UInt16" band="1">
> <SimpleSource>
> <SourceFilename
> relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFilen
> ame> <SourceDimension RasterXDim="0" RasterYDim="1" />
> <SourceBand>1</SourceBand>
> <SourceProperties RasterXSize="360" RasterYSize="180"
> DataType="UInt16" BlockXSize="360" BlockYSize="180" />
> </SimpleSource>
> </VRTRasterBand>
> Once user specifies correct dimensions by editing VRT, it can be
> used by GDAL HDF4/HDF5 drivers and the HDF drivers read the data
> correctly for GDAL's image buffer.
> Do you think it's right and feasible approach to solve wrong X/Y
> dimension order problem? Or do you have any other existing solution
> that can mitigate this problem in GDAL? The GEE project team has
> experimented the idea by creating another separate XML file [2] but I
> think it's time to sync with GDAL development team and come up with
> the most elegant solution. In my opinion, VRT looks best and I wish
> GDAL development team can give me some feedback on this idea.
Joe,
I would rather suggest to add open options to the drivers and pass them with
the exiting VRT OpenOptions element, rather than adding a new element in the
VRT that would be specific of a few drivers
<SimpleSource>
<SourceFilename>
relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFilename>
<OpenOptions>
<OOI key="RASTERXDIM">0</OOI>
<OOI key="RASTERYDIM">1</OOI>
</OpenOptions>
<SourceProperties RasterXSize="360" RasterYSize="180" DataType="UInt16"
</SimpleSource>
Which is equivalent to:
gdalinfo HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7 -oo RASTERXDIM=0 -oo
RASTERYDIM=0
Even
http://www.spatialys.com
