[gdal-dev] 4th band as ALPHA on warp
Even Rouault
even.rouault at spatialys.com
Sun Aug 7 10:20:05 PDT 2016
Le samedi 06 août 2016 15:20:54, Fernando Ribeiro a écrit :
> Dear list,
> Currently we are working with 4 band tifs, first 3 bands as normal RBG
> and the 4th as IR. On performing a warp operation from and to a VRT,
> GDAL seems considering the 4th band as alpha, resulting in full black
> pixels if 4th band value =0.
gdalwarp will consider the 4th band as alpha... only if it is effectively
tagged as alpha in the source. You can check it with gdalinfo
> Some attempts were made to solve this issue, so far without success:
> - Using the warp creation options PHOTOMETRIC=RGB and ALPHA=NO
This will not influence the warping kernel.
> - Manually editing the source VRT and replace Alpha color interpretation
> to Undefined
This one should work. Strange that this doesn't work for you.
> Does anyone have more suggestions?
> Thank you
http://www.spatialys.com
