[gdal-dev] GDAL raster processing library?
Ari Jolma ari.jolma at gmail.com
Mon Aug 8 05:56:12 PDT 2016
Sorry for missing this last month due to holidays.
In fact in my approach I do not want to limit to single pixel operations
but support neighborhood operations too. That is necessary for watershed
analysis for example. Making sure that the neighborhood is readily
available for computations is probably what is causing the biggest
problem for the code. I also have a callback support. See for example
https://github.com/ajolma/gdal/blob/trunk/gdal/map_algebra/test.cpp
where on the lines 5 to 12 is a callback function.
When I left the code for my extended holidays I was doing profiling and
intended to test another approach for caching. Now the caching is based
on the native GDAL blocks, which is efficient for going through a single
dataset. Since the block may be different for different datasets this
approach may not be the best when there are more than one dataset. For
example the raster algebra in QGIS uses an approach where the block is
the same for all datasets. That simplifies the code and may be very
efficient as a whole.
I'll be at the code sprint in FOSS4G 2016 and that would be a good place
to discuss the RFC too.
Best,
Ari
13.07.2016, 10:09, James Ramm kirjoitti:
> Peter,
> I think 'Grid Algebra' would be what Ari Jolma is proposing here:
> https://trac.osgeo.org/gdal/wiki/rfc62_raster_algebra
> As Even pointed out, there is some overlap, though my proposal is
> technically very different.
> The key differences I see are:
> - Users can submit functions which operate on each sub window of the
> raster, rather than an algebraic expression. This potentially allows
> for much more complicated algorithms to be used (e.g. I dont think it
> would be possible to run a watershed segmentation with a raster
> algebra implementation, or to have algorithms which behave differently
> depending on the 'location' within the raster or the values of
> surrounding pixels etc etc).
> - Functions can be chained together for a complex processing
> toolchain. Some overlap with VRT here, although again this introduces
> a little more flexibility.
> On 12 July 2016 at 15:47, Peter Halls <p.halls at york.ac.uk
> <mailto:p.halls at york.ac.uk>> wrote:
>     James,
>           in reality, are you not requesting an implementation of
>     Tomlin's 'Grid Algebra' in GDAL?  That defines the whole range of
>     functions from whole raster to pixel and has the distinct
>     advantage of being both published and extremely well known because
>     of other implementations ... which also provide ready-made
>     reference bases for the GDAL implementors ...
>     Best wishes,
>     Peter
>     On 12 July 2016 at 15:39, James Ramm <jamessramm at gmail.com
>     <mailto:jamessramm at gmail.com>> wrote:
>         Hi Even,
>         The difference I see with pixel functions is that, as far as I
>         understand, the pixel function is applied per pixel, so there
>         is no possibility of e.g. the pixel buffer when have the
>         function apply to 'blocks'.
>         I may be way off, but many of the algorithms we deal with
>         require some kind of neighbourhood search - a polygonise
>         algorithm or flow direction algorithm being good examples.
>         I dont think VRT pixel functions allow this?
>         So in that sense I'd see a VRT being 'just' another potential
>         input data source.
>         Perhaps VRT pixel functions could be expanded to also allow
>         'window' functions?
>         A downside is it requires creating a VRT even when you only
>         want to apply a such a function to a single dataset. Small
>         effort, but still a bit more than throwing in any GDALDataset
>         to be processed.
>         I see the overlap with raster algebra, although yes
>         On 12 July 2016 at 14:55, Even Rouault
>         <even.rouault at spatialys.com
>         <mailto:even.rouault at spatialys.com>> wrote:
>             James,
>             There's some intersection with Ari's proposal :
>             https://trac.osgeo.org/gdal/wiki/rfc62_raster_algebra . At
>             least regarding the
>             overall purposes, since technically this is quite different.
>             Actually what you propose is very close to the existing
>             VRT pixel functions of
>             derived bands. See "Using Derived Bands" in
>             http://www.gdal.org/gdal_vrttut.html . In the last days,
>             we've merged
>             Antonio's work regarding a predefined set of pixel functions.
>             Perhaps some extension to allow passing user parameters to
>             the pixel func
>             could be useful. It is possible to use pixel functions
>             from Python as shown in
>             https://github.com/OSGeo/gdal/blob/trunk/autotest/gcore/testnonboundtoswig.py#L303
>             although this is a bit ugly as it uses ctypes and not
>             SWIG. But should be
>             possible through SWIG by introducing proper types
>             similarly to what is done
>             for the progress functions or error handler functions.
>             Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160808/ce10d765/attachment-0001.html>
