[gdal-dev] 4th band as ALPHA on warp
    Fernando Ribeiro
    fernando.ribeiro at geo-solutions.it
    Mon Aug  8 15:32:44 PDT 2016
Thank you Even for this new feature.
Hope it will be handy to many more!
On 08/08/2016 11:26 AM, Even Rouault wrote:
> Le lundi 08 août 2016 09:30:53, Daniele Romagnoli a écrit :
>> Hi Even,
>> my usual question would be: any plan to backport it? :-)
> Not really. I guess this is a new feature.
> As currently, our policy is to be rather conservative for what goes in stable
> branches, so people can upgrade from one micro version to another one
> blindlessly.
> Regarding that particular feature, it could potentially be backported, but
> then where to draw the limit ? At some point, one such backport will undoubtly
> cause a regression elsewhere, or will have bugs, causing more stabilization
> work in stable branches.
> Potential solutions:
> - More frequent major.minor.0 releases that our ~ 1 year schedule
> - Less conservative policy backport policy in regular stable branches that
> would allow some new features to be added, but within the current limits of no
> ABI change, no backward incompatibilities.
> - An extra -backport branch that would have a less conservative policy. To be
> defined what would be the limits: ABI changes allowed or not ?, backward
> incompatibilities ? Would potentially only of interest for people who can
> build from source as it would be unlikely to be widely packaged.
> All would need extra staffing / funding.
> Another option that already exists: live on the bleeding edge and build from
> trunk ;-)
> Even
>> Cheers,
>> Daniele
>> On Sun, Aug 7, 2016 at 10:38 PM, Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Le dimanche 07 août 2016 19:20:05, Even Rouault a écrit :
>>>> Le samedi 06 août 2016 15:20:54, Fernando Ribeiro a écrit :
>>>>> Dear list,
>>>>> Currently we are working with 4 band tifs, first 3 bands as normal
>>>>> RBG and the 4th as IR. On performing a warp operation from and to a
>>>>> VRT, GDAL seems considering the 4th band as alpha, resulting in full
>>>>> black pixels if 4th band value =0.
>>>> gdalwarp will consider the 4th band as alpha... only if it is
>>>> effectively tagged as alpha in the source. You can check it with
>>>> gdalinfo
>>>>> Some attempts were made to solve this issue, so far without success:
>>>>> - Using the warp creation options PHOTOMETRIC=RGB and ALPHA=NO
>>>> This will not influence the warping kernel.
>>>>> - Manually editing the source VRT and replace Alpha color
>>> interpretation
>>>>> to Undefined
>>>> This one should work. Strange that this doesn't work for you.
>>>>> Does anyone have more suggestions?
>>> I've just committed an improvement in trunk: "gdalwarp: add a -nosrcalpha
>>> option to wrap the alpha band as a regular band and not as the alpha
>>> band"
>>>>> Thank you
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Regards,
Fernando Ribeiro
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Fernando Ribeiro
DevOps / Support Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:   +39 0584 1660272
mob:   +39 333 	8128928
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160809/b5f4584d/attachment.html>
