[gdal-dev] Tiling with overlap
Luca Delucchi lucadeluge at gmail.com
Tue Aug 9 01:12:40 PDT 2016
On 8 August 2016 at 21:01, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hei Madi,
> Given that you are quite familiar with GRASS GIS here a GRASS / GDAL
> solution:
> 1.      Patch all tiles into one VRT with gdalbuildvrt
> 2.      Link the VRT and the individual tiles to GRASS (r.external)
> 3.      Loop over the tiles and adjust you region accordingly and apply what
> GRASS module you like.
> So something like this:
> gdalbuildvrt ...
> r.external input=vrt ...
> r.external input=tile ...
> for tile in $(g.list type=raster ...)
> do
> g.region -p raster=$tile n=n+x s=s-x w=w-x e=e+x (where x is your desired
> overlap in map units)
> r.*
> done
I didn't answer before because I was thinking to go OT but in GRASS
you can use t.tile with overlaps
https://grass.osgeo.org/grass70/manuals/r.tile.html
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
