[gdal-dev] GDALSuggestedWarpOutput return wrong pnPixels and pnLines
Vincent BERNAT
vincent.bernat at magellium.fr
Wed Aug 17 05:10:19 PDT 2016
Hi all,
I work with gdal-2.1.0 on CentOS
I have an image and when I want to use the GDALSuggestedWarpOutput, it returns no failure but
pnPixels = 2173
pnLines = 0
What could be the problem ?
Thanks a lot.
Regards,
Vincent
here are the gdalinfo :
Driver: SRP/Standard Raster Product (ASRP/USRP)
Files: VALIDATION_KO/ANTIME/ANTIME01.IMG
VALIDATION_KO/ANTIME/ANTIME01.GEN
VALIDATION_KO/ANTIME/ANTIME01.QAL
Size is 1536, 1536
Coordinate System is:
PROJCS["UTM Zone 60, Northern Hemisphere",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",177],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (722080.000000000000000,5320960.000000000000000)
Pixel Size = (5.000000000000000,-5.000000000000000)
Metadata:
SRP_CLASSIFICATION=U
SRP_CREATIONDATE=20070118
SRP_EDN=0
SRP_NAM=ANTIME
SRP_PRODUCT=USRP
SRP_REVISIONDATE=20070118
SRP_SCA=50000
SRP_ZNA=60
Corner Coordinates:
Upper Left ( 722080.000, 5320960.000) (179d58'38.83"E, 48d 0'11.97"N)
Lower Left ( 722080.000, 5313280.000) (179d58'24.55"E, 47d56' 3.55"N)
Upper Right ( 729760.000, 5320960.000) (179d55'11.03"W, 48d 0' 2.20"N)
Lower Right ( 729760.000, 5313280.000) (179d55'25.81"W, 47d55'53.80"N)
Center ( 725920.000, 5317120.000) (179d58'23.36"W, 47d58' 2.92"N)
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
NoData Value=0
Color Table (RGB with 256 entries)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160817/109dad97/attachment-0001.html>
