[gdal-dev] Arc File Geodatabase
James Ramm
jamessramm at gmail.com
Sun Aug 21 05:17:48 PDT 2016
Yes, there is some form 2d index - each raster has a corresponding
.col_index.atx, .row_index.atx, _.blk_key_index.atx and .band_index.atx
files. I've not looke at how they work together so far.
On Sunday, 21 August 2016, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi Richard,
> > I saw a posting from July
> > <https://lists.osgeo.org/pipermail/gdal-dev/2016-July/044761.html> about
> > work towards deciphering the Arc File Geodatabase Raster format.
> > Inspired, I did some work today and successfully extracted a raster from
> > a geodatabase.
> > Using Even Rouault's /dump_gdbtable/ as a starting point, I decompressed
> > the raster blobs using zlib, as suggested in the posting.
> > For my raster, this gave 128x128 big-endian 32-bit floating-point values
> > with a trailer of about 512 bytes.
> > Assembling these 128x128 tiles using the col_nbr and row_nbr fields
> > resulted in the raster coming out.
> > I've uploaded my fork, along with appropriate input data and a command
> > to run it all (see README.md) to https://github.com/r-barnes/
> dump_gdbtable.
> > What remains is to link metadata (block size, band_width, band_height)
> > to the raster so the output can be sized appropriately, the data type
> > deduced automatically, and projections saved. This is probably just a
> > matter of linking the appropriate rows from some of the lower-numbered
> > gdbtables with the files containing the raster data. It might also be
> > nice to determine whether zlib is always being used, but I assume an
> > error could be thrown if an unexpected compression format is encountered.
> One can expect other compression formats according to :
> http://desktop.arcgis.com/en/arcmap/10.3/manage-data/
> raster-and-images/raster-compression.htm
> None of them seem to be particularly difficult given what GDAL supports
> ("raw" RLE and "raw" LZW
> would probably require a bit more work as there is no direct drivers that
> support them, although they
> are codecs of some other GDAL drivers like TIFF, and so could be perhaps
> wrapped on the fly in a in-memory TIFF)
> What they call LZ77 must be the ZLib one (according to
> https://en.wikipedia.org/wiki/Zlib ZLib's DEFLATE is a modified LZ77)
> > I'm interested in seeing GDAL include the ability to translate Arc File
> > Geodatabase Rasters into other (less proprietary) formats.
> > What is a good way to move forward with that?
> "A bit" of coding !
> ogr/ogrsf_frmts/openfilegdb/filegdbtable.cpp should probably be extended
> to offer
> the low level access to the rasters.
> And ogropenfilegdbdatasource.cpp to implement the GDAL Raster API using
> the above.
> Regarding efficiency of random reading of tiles, I'm wondering if they
> have some form of 2D (row, column)
> indexing or perhaps 3D (row, column, pyramid_level). For the vector part,
> I only addressed the case
> of 1D indexes.
> As a fallback sequential reading through the records could still be used,
> perhaps with some tricks to read only the start
> of the records to get the (row, column, pyramid_level) values, if located
> at the beginning of it,
> and not the raster data if not needed.
> Even
> > Best regards,
> > Richard Barnes
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <javascript:;>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160821/d00fa36c/attachment.html>
