[gdal-dev] Build GDAL on iOS for iPhone
Jesse Crocker
jesse at gaiagps.com
Mon Aug 22 06:00:45 PDT 2016
Hi Gane,
Here is a link to my gdal iOS build script, last tested with 1.11.2, but it
should still work with newer 1.11.x releases,
https://gist.github.com/JesseCrocker/22eee94485bce5b3a6ea
Jesse
On Fri, Aug 19, 2016 at 1:15 AM, Gane R <gane.prog at gmail.com> wrote:
> Hi all,
> I had a change to see the link
> http://stackoverflow.com/questions/12643898/incorporating-gdal-ogr-into-
> an-ios-project-a-quick-guide
> This was guiding to build with Xcode 4.0, the above link says that it
> doesn't work with Xcode version above 4.0
> I just wanted to build GDAL as static library for iPhone and use the OGR
> library there in iPhone.
> I modified the build script as shown here, build_gdal_ios_cus.sh
> #!/bin/bash
> if [ "$#" -eq 0 ]
> then
> echo "No parameters supplied"
> else
> default_prefix="${HOME}/Documents/iOS_GDAL"
> prefix="${default_prefix}"
> if [ "$1" == "arm" ]
> then
> arch="armv7"
> fi
> if [ "$1" == "sim" ]
> then
> arch="i386"
> fi
> if [ "$2" == "iPhone" ]
> then
> export PATH=$PATH:/Users/w1/ctools
> echo $PATH
> #extra_cflags="-m${thumb_opt:-no-thumb} -mthumb-interwork"
> platform="iPhone"
> platform_dir="/Applications/Xcode.app/Contents/Developer/
> Toolchains/XcodeDefault.xctoolchain"
> platform_bin_dir="${platform_dir}/usr/bin"
> platform_sdk_dir="/Applications/Xcode.app/
> Contents/Developer/Platforms/iPhoneOS.platform/Developer/
> SDKs/iPhoneOS.sdk/"
> prefix="${prefix}/${arch}/${platform}.platform/iPhoneOS.sdk"
> echo library will be exported to $prefix
> #export CC="${platform_bin_dir}/clang"
> export INCDIR="/Applications/Xcode.app/Contents/Developer/
> Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/include"
> export INCDIR1="/Applications/Xcode.app/Contents/Developer/
> usr/include/c++/4.2.1/tr1"
> export INCDIRCPP="/Applications/Xcode.app/Contents/Developer/
> usr/include/c++/4.2.1"
> #export CFLAGS="-std=gnu99 -nostdinc -I${INCDIR} -I${INCDIRCPP}
> -I${INCDIR1} -arch ${arch} -pipe -Os -gdwarf-2 -isysroot
> ${platform_sdk_dir}"
> export CFLAGS="-std=gnu99 -nostdinc -I${INCDIR} -I${INCDIR1} -arch
> ${arch} -pipe -Os -gdwarf-2 -isysroot ${platform_sdk_dir}"
> export LDFLAGS="-arch ${arch} -isysroot ${platform_sdk_dir}"
> export CXXFLAGS="-stdlib=libstdc++ -nostdinc++ -I${INCDIR}
> -I${INCDIRCPP} -arch ${arch} -pipe -Os -gdwarf-2 -isysroot
> fi
> then
> platform="iPhoneSimulator"
> fi
> ./configure \
> --prefix="${prefix}" \
> --host="${arch}-apple-darwin" \
> --disable-shared \
> --enable-static \
> --with-unix-stdio-64=no
> fi
> I created symbolic links to
> armv7-apple-darwin-gcc -> /usr/bin/llvm-gcc
> armv7-apple-darwin-g++ -> /usr/bin/llvm-g++
> Actually points
> llvm-g++ -> clang++
> llvm-gcc -> clang
> Above script was invoked as
> ./build_gdal_ios_cus.sh arm iPhone
> Configure succeeded.
> when I run
> make
> I get error like this
> (cd alg; /Applications/Xcode.app/Contents/Developer/usr/bin/make)
> /bin/sh /Users/w1/gdal-2.1.0/libtool --mode=compile --tag=CC
> armv7-apple-darwin-gcc -I/Users/w1/gdal-2.1.0/port
> -I/Users/w1/gdal-2.1.0/gcore -I/Users/w1/gdal-2.1.0/alg
> -I/Users/w1/gdal-2.1.0/ogr -I/Users/w1/gdal-2.1.0/ogr/ogrsf_frmts
> -I/Users/w1/gdal-2.1.0/gnm -I/Users/w1/gdal-2.1.0/apps -std=gnu99 -nostdinc
> -I/Applications/Xcode.app/Contents/Developer/Platforms/
> iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/include/c++/4.2.1/tr1
> -arch armv7 -pipe -Os -gdwarf-2 -isysroot /Applications/Xcode.app/
> Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/
> -Wall -Wdeclaration-after-statement -Wextra -Winit-self -Wunused-parameter
> -Wmissing-prototypes -Wmissing-declarations -Wformat
> -Werror=format-security -Wno-format-nonliteral -Wshorten-64-to-32 -Wshadow
> -Werror=vla -Wdeclaration-after-statement -Wnull-dereference
> -DINTERNAL_QHULL -Ilibqhull -DOGR_ENABLED -I/Users/w1/gdal-2.1.0/port
> -DGDAL_COMPILATION -c -o delaunay.lo delaunay.c
> libtool: compile: armv7-apple-darwin-gcc -I/Users/w1/gdal-2.1.0/port
> -DGDAL_COMPILATION -c delaunay.c -o delaunay.o
> In file included from delaunay.c:62:
> In file included from /w1/gdal-2.1.0/alg/internal_qhull_headers.h:977:
> libqhull/libqhull.c:64:34: error: use of undeclared identifier 'DBL_MAX'
> if (qh RERUN || qh JOGGLEmax < REALmax/2)
> libqhull/user.h:145:17: note: expanded from macro 'REALmax'
> #define REALmax DBL_MAX
> libqhull/libqhull.c:301:37: error: use of undeclared identifier 'DBL_MAX'
> if (!qh RERUN && qh JOGGLEmax < REALmax/2) {
> libqhull/libqhull.c:325:49: error: use of undeclared identifier 'DBL_MAX'
> if (qh TRACEpoint != -1 || qh TRACEdist < REALmax/2 || qh
> TRACEmerge) {
> libqhull/
> It seems that the float.h or cfloat does't have such definition or
> implementation for arm target
> Questions:
> 1. Can we build GDAL for iPhone with arm7 targert ??
> 2. Did I have missed or misconfigured something ???
> Any suggestion or references on web will be of great help.
> Thanks
> Gane
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160822/f63cb232/attachment.html>
