[gdal-dev] No way to set natural block size ?
Tim Keitt tkeitt at utexas.edu
Wed Aug 24 05:19:27 PDT 2016
It is set at the time of dataset creation and cannot be changed without
creating a new dataset. Check which drivers allow you to set a tiled layout
on disk.
THK
http://www.keittlab.org/
On Wed, Aug 24, 2016 at 6:44 AM, BRUNEL Samuel <
samuel.brunel at thalesgroup.com> wrote:
> Hi,
> It's easy to fetch the "natural" block size of a band with "void
> GDALRasterBand::GetBlockSize(int *pnXSize, int *pnYSize)" but I don't
> understand how pnXSize and pnYsize are set in gdal.
> I'm using gdal 1.11.4
> Anyone know the answer ?
> Best regards,
> Samuel
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160824/a212c3bc/attachment.html>
