[gdal-dev] GDAL 2.1.0 build error (32 bit, Mac)
Calogero Mauceri
mauceri at actgate.com
Fri Aug 26 01:54:00 PDT 2016
I defined HAVE_LONG_LONG in cpl_config.h and indeed it worked.
Not sure why that macro does not get defined automatically by the
configure script.
Thanks for your hint,
Calogero
Il 8/25/2016 3:10 PM, Calogero Mauceri ha scritto:
> Thanks Even for your reply.
> I had a look to port/cpl_config.h and in both cases (32 and 64 bit)
> the following line is commented
> /* Define to 1, if your compiler supports long long data type */
> /* #undef HAVE_LONG_LONG */
> I tried --with-macosx-framework and "-arch i386 -arch x86_64" but
> unfortunately did not work:
> --with-macosx-framework is not recognized as a valid option and if I
> add -arch x86_64 flag I get the following configuration errors
> checking for otool... otool
> checking for otool64... no
> checking for -single_module linker flag... Running ld for i386 ...
> Running ld for x86_64 ...
> yes
> checking for -exported_symbols_list linker flag... yes
> checking for -force_load linker flag... Running ld for i386 ...
> yes
> checking how to run the C preprocessor... /lib/cpp
> configure: error: in `/Users/mauceri/work/dev/libs/gdal-2.1.1':
> configure: error: C preprocessor "/lib/cpp" fails sanity check
> To add more information, GDAL 1.11.5 and 2.0.3 properly build in 32
> bits on the same machine.
> Calogero
> Il 8/25/2016 1:48 AM, Even Rouault ha scritto:
>> On Wednesday 24 August 2016 16:00:02 Calogero Mauceri wrote:
>>> Hi all,
>>> I'm trying to build GDAL 2.1.0 in 32 bit on Mac OS X.
>>> I set the following environment variables
>>> export CFLAGS="-arch i386"
>>> export CXXFLAGS="-arch i386"
>>> export CPPFLAGS="-arch i386"
>>> export LDFLAGS="-arch i386"
>>> and then execute
>>> ./configure
>>> The build stops with the following error
>>> /bin/sh /Users/mauceri/work/dev/libs/gdal-2.1.1/libtool --mode=compile
>>> --tag=CXX g++ -I/Users/mauceri/work/dev/libs/gdal-2.1.1/port
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/gcore
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/alg
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/ogr
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/ogr/ogrsf_frmts
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/gnm
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/apps -arch i386 -Wall -Wextra
>>> -Winit-self -Wunused-parameter -Wformat -Werror=format-security
>>> -Wno-format-nonliteral -Wshorten-64-to-32 -Wshadow -Werror=vla
>>> -Wnull-dereference -Wunused-private-field -Wmissing-prototypes
>>> -Wmissing-declarations -Wnon-virtual-dtor -Woverloaded-virtual
>>> -fno-operator-names -I.. -I../jpeg -DHAVE_LIBJPEG -I../jpeg/libjpeg
>>> -DINTERNAL_LIBGEOTIFF -Ilibgeotiff -DINTERNAL_LIBTIFF -Ilibtiff
>>> -DBIGTIFF_SUPPORT -DOGR_ENABLED -arch i386
>>> -I/Users/mauceri/work/dev/libs/gdal-2.1.1/port -DGDAL_COMPILATION -c -o
>>> ../o/geotiff.lo geotiff.cpp
>>> libtool: compile: g++ -I/Users/mauceri/work/dev/libs/gdal-2.1.1/port
>>> geotiff.cpp -fno-common -DPIC -o ../o/.libs/geotiff.o
>>> geotiff.cpp:9771:21: error: no member named 'my_function' in
>>> 'CPLStaticAssert<false>'; did you mean
>>> 'CPLStaticAssert<true>::my_function'?
>>> if( bSwap ) CPL_SWAP64PTR(&nTmp);
>>> /Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:655:5: note:
>>> expanded from macro 'CPL_SWAP64PTR'
>>> CPL_STATIC_ASSERT_IF_AVAILABLE(sizeof(*(x)) == 1 ||
>>> sizeof(*(x)) ==
>>> 8); \
>>> /Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:605:43: note:
>>> expanded from macro 'CPL_STATIC_ASSERT_IF_AVAILABLE'
>>> #define CPL_STATIC_ASSERT_IF_AVAILABLE(x) CPL_STATIC_ASSERT(x)
>>> /Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:604:30: note:
>>> expanded from macro 'CPL_STATIC_ASSERT'
>>> #define CPL_STATIC_ASSERT(x) CPLStaticAssert<x>::my_function()
>>> /Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:599:17: note:
>>> 'CPLStaticAssert<true>::my_function' declared here
>>> static void my_function() {}
>>> Do you have any idea on how to fix this?
>> One of the reason for which it would happen is that GUIntBig type
>> doesn't
>> resolve to a 64 bit integer but to a 32 bit one. And that could
>> happen if the
>> HAVE_LONG_LONG macro is not defined in the port/cpl_config.h file
>> that is
>> generated by ./configure. Now I'm not Mac savvy enough to tell you
>> why that
>> would happen...
>> Quickly looking at https://trac.osgeo.org/gdal/wiki/BuildingOnMac ,
>> it seems
>> you can/should specify --with-macosx-framework and possibly use
>> "-arch i386 -
>> arch x86_64"
>> Even
Calogero Mauceri
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
