[gdal-dev] Public XYM or XYZM datasets?
Ari Jolma
ari.jolma at gmail.com
Sun Aug 28 00:48:15 PDT 2016
The Finnish national road data was my motivation to add M to OGR.
You can download it from
https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu
The page is also in English (click EN on top left)
The "R" data is the one you want.
The meta data etc is probably in Finnish only so you may need to
experiment. M values are used to encode point-like attribute data into
the line strings.
Good luck,
Ari
26.08.2016, 01:43, Carl Godkin kirjoitti:
> Hi,
> While I had read about XYM and XYZM on the mailing list a few months
> ago, I had no experience with those geometry types until today when I
> happened to stumble on
> http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip
> which contains a shapefile of trails around Boulder, Colorado that has
> Geometry: Measured Line String
> in GDAL 2.1's ogrinfo.
> I would like to find some other datasets with XYM (and/or XYZM)
> geometry for testing.
> I didn't see any associated with the RFC or tickets associated with it.
> Can anyone point me to any others? Thanks very much,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160828/f45bd349/attachment.html>
