[gdal-dev] NITF TRE parsing - possible extensions for MIE4NITF
Brad Hards
bradh at frogmouth.net
Sun Aug 28 04:25:07 PDT 2016
MIE4NITF 1.1 can be downloaded from
https://nsgreg.nga.mil/NSGDOC/files/doc/Document/MIE4NITF%20v%201_1.zip
(see https://nsgreg.nga.mil/doc/view?i=4205 for info).
> Is the UINT naming somewhat standardized ? Otherwise perhaps uint_be to
> reflect
> that it is binary encoded with big endianness (contrary to integer)
I can live with either.
The spec says:
5.9.2 MIE4NITF defined data types
MIE4NITF defines several data types that are used within its TREs. These data
types are defined in this section. Table 8 introduces an unsigned integer type
that is used in the MIE4NITF TREs. The UINTn nomenclature is somewhat
standardized in the computing world but it is included here to unambiguously
define its use. All bytes in the UINTn data type are stored in big endian
order and all bits within those bytes are stored most significant bit first.
> Not sure to have understood the structure of those TREs and couldn't find
> any
> public resource describing them.
Sorry, should have linked to those in the initial email. In the spec (above),
see
5.9.3.6 Freespace TRE (FREESA)
5.9.4.8 Frame-Synchronous Metadata Wrapper TRE (FSYNWA)
5.9.4.9 Frame-Asynchronous Metadata Wrapper TRE (FASYWA)
I would caution that it's a bit confusing the first time.
Brad
