[gdal-dev] Public XYM or XYZM datasets?
Ari Jolma
ari.jolma at gmail.com
Sun Aug 28 22:15:36 PDT 2016
In the download email you should have K and R data set options (two
URLs). Only R has measured geometries.
Ari
29.08.2016, 01:43, Carl Godkin kirjoitti:
> Thank you very much for the response. (This isn't the first time I've
> found great example data from Finland, by the way. When I was
> experimenting with Lidar data a few years ago I found that Finland's
> collection was enormous!)
> However, I can't see what you mean by the "R" data. I selected
> various "Map Layers" and downloaded a few random shapefiles and none
> had "Measured" geometry (according to ogrinfo).
> Thanks for your help. Sorry if this is a dumb question!
> carl
> On Sun, Aug 28, 2016 at 12:48 AM, Ari Jolma <ari.jolma at gmail.com
> <mailto:ari.jolma at gmail.com>> wrote:
> The Finnish national road data was my motivation to add M to OGR.
> You can download it from
> https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu
> <https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu>
> The page is also in English (click EN on top left)
> The "R" data is the one you want.
> The meta data etc is probably in Finnish only so you may need to
> experiment. M values are used to encode point-like attribute data
> into the line strings.
> Good luck,
> Ari
> 26.08.2016, 01:43, Carl Godkin kirjoitti:
>> Hi,
>> While I had read about XYM and XYZM on the mailing list a few
>> months ago, I had no experience with those geometry types until
>> today when I happened to stumble on
>> http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip
>> <http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip>
>> which contains a shapefile of trails around Boulder, Colorado
>> that has
>> Geometry: Measured Line String
>> in GDAL 2.1's ogrinfo.
>> I would like to find some other datasets with XYM (and/or XYZM)
>> geometry for testing.
>> I didn't see any associated with the RFC or tickets associated
>> with it.
>> Can anyone point me to any others? Thanks very much,
>> carl
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
> _______________________________________________ gdal-dev mailing
> list gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160829/3339457c/attachment-0001.html>
