[gdal-dev] Public XYM or XYZM datasets?
Ari Jolma ari.jolma at gmail.com
Tue Aug 30 06:35:59 PDT 2016
I think you need to select "DIGIROAD" on the left first. Then you should
get something like
> Hi,
> Your selected digiroad data sets from the Finnish Transport Agency are
> available at the following link:
> https://extranet.liikennevirasto.fi/livi/digiroad/Maakuntajako_DIGIROAD_K_EUREF-FIN/UUSIMAA.zip
> https://extranet.liikennevirasto.fi/livi/digiroad/Maakuntajako_DIGIROAD_R_EUREF-FIN/UUSIMAA.zip
> The download link is valid for 10 days. For further information,please
> contact us at
> Paikkatieto at liikennevirasto.fi
> Do not reply to this email.
> Thank you for your order!
> The data set descriptions are available at:
> http://www.liikennevirasto.fi/avoindata/tietoaineistot
> Digiroad materialföljebrev hittas pÄ Digiroads hemsida:
> http://www.digiroad.fi/dokumentit/sv_SE/foljebrev/
It seems that these shapefiles have M:
1: DR_LINKKI (3D Measured Line String)
1: DR_NOPEUSRAJOITUS (3D Measured Line String)
1: DR_SUURIN_SALLITTU_AKSELIMASSA (3D Measured Line String)
1: DR_SUURIN_SALLITTU_KORKEUS (3D Measured Line String)
1: DR_SUURIN_SALLITTU_MASSA (3D Measured Line String)
1: DR_SUURIN_SALLITTU_PITUUS (3D Measured Line String)
1: DR_SUURIN_SALLITTU_TELIMASSA (3D Measured Line String)
1: DR_VALAISTU_TIE (3D Measured Line String)
1: DR_YHDISTELMAN_SUURIN_SALLITTU_MASSA (3D Measured Line String)
Sorry, in Finnish. For example "DR_NOPEUSRAJOITUS" probably has the
speed limit on the road as M.
Ari
30.08.2016, 16:27, Jaak Laineste kirjoitti:
> It looks like I get only one link with some selected layers. Which
> layers are worth to try?
> /Your selected spatial data sets from the Finnish Transport Agency are
> https://extranet.liikennevirasto.fi/livi/inspire-downloads/41...zip
> contact us at
> Jaak
>> On 29 Aug 2016, at 08:15, Ari Jolma <ari.jolma at gmail.com
>> <mailto:ari.jolma at gmail.com>> wrote:
>> In the download email you should have K and R data set options (two
>> URLs). Only R has measured geometries.
>> Ari
>> 29.08.2016, 01:43, Carl Godkin kirjoitti:
>>> Thank you very much for the response.  (This isn't the first time
>>> I've found great example data from Finland, by the way.  When I was
>>> experimenting with Lidar data a few years ago I found that Finland's
>>> collection was enormous!)
>>> However, I can't see what you mean by the "R" data.  I selected
>>> various "Map Layers" and downloaded a few random shapefiles and none
>>> had "Measured" geometry (according to ogrinfo).
>>> Thanks for your help.  Sorry if this is a dumb question!
>>> carl
>>> On Sun, Aug 28, 2016 at 12:48 AM, Ari Jolma <ari.jolma at gmail.com
>>>     The Finnish national road data was my motivation to add M to OGR.
>>>     You can download it from
>>>     https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu
>>>     <https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu>
>>>     The page is also in English (click EN on top left)
>>>     The "R" data is the one you want.
>>>     The meta data etc is probably in Finnish only so you may need to
>>>     experiment. M values are used to encode point-like attribute
>>>     data into the line strings.
>>>     Good luck,
>>>     Ari
>>>     26.08.2016, 01:43, Carl Godkin kirjoitti:
>>>>     Hi,
>>>>     While I had read about XYM and XYZM on the mailing list a few
>>>>     months ago, I had no experience with those geometry types until
>>>>     today when I happened to stumble on
>>>>     http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip
>>>>     <http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip>
>>>>     which contains a shapefile of trails around Boulder, Colorado
>>>>     that has
>>>>         Geometry: Measured Line String
>>>>     in GDAL 2.1's ogrinfo.
>>>>     I would like to find some other datasets with XYM (and/or XYZM)
>>>>     geometry for testing.
>>>>     I didn't see any associated with the RFC or tickets associated
>>>>     with it.
>>>>     Can anyone point me to any others?  Thanks very much,
>>>>     carl
>>>>     _______________________________________________
>>>>     gdal-dev mailing list
>>>>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>     <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
>>>     _______________________________________________ gdal-dev mailing
>>>     list gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> _______________________________________________ gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160830/1e63a2ce/attachment.html>
