[gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Aug 30 13:41:52 PDT 2016
Very cool Ivan, I'll try this first thing in the morning, when my brain
is working best :) -jeff
On 2016-08-30 4:21 PM, Ivan Lucena wrote:
> Hi Mateusz/Jeff,
> Please try the new version of "makegdal_gen.bat".
> It will generate projects ready to use in newer version of Visual Studio.
> I tested it only in VC++ 12.0 (VS 2013).
> Add comments, if you like, to: https://trac.osgeo.org/gdal/ticket/6635
> Regards,
> Ivan
> *From:* Ivan Lucena <lucena_ivan at hotmail.com>
> *Sent:* Monday, August 15, 2016 3:37 PM
> *To:* Mateusz Loskot; Jeff McKenna
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual
> Mateusz,
> Thanks for the tip.
> Yes, the project is loaded but it is not a "Makefile Project" anymore,
> so it's basically useless.
> In previous VS versions once the .vsproj file was loaded and upgraded
> you could press F7 and "nmake -f makefile.vc" would start running inside
> the IDE.
> That means you would have all the advantages of the IDE (debuggin/cross
> reference/refactoring/etc.) but still using the settings of nmake.local
> and running makefiles.
> I am using VS 2013. Is that the same for you on VS 2015?
> Thanks,
> Ivan
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Mateusz
> Loskot <mateusz at loskot.net>
> *Sent:* Thursday, August 4, 2016 5:44 PM
> *To:* Jeff McKenna
> On 4 August 2016 at 17:52, Jeff McKenna <jmckenna at gatewaygeomatics.com>
> wrote:
>> On 2016-08-04 11:07 AM, Mateusz Loskot wrote:
>>> 1. makegdal_gen 10.00 32 > makegdal10.vcproj
>>> 2. Launch VS2015
>>> 3. File > Open > Project/Solution...
>>> 4. Select makegdal10.vcproj
>>> 5. Accept to upgrade
>> Can we make sure to document these steps, so they are not lost in emails?
>> Somewhere on the BuildHints wiki would be great.  Possibly here?
>> https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
> BuildingOnWindows – GDAL
> <https://trac.osgeo.org/gdal/wiki/BuildingOnWindows>
> trac.osgeo.org
> GDAL can be built on Win32 platforms using MS VC++ 6.x and MS Visual
> Studio .NET (C++). The source distribution includes NMAKE compatible
> makefiles for use from the ...
