[gdal-dev] WMTS - Need TileLevel option Servers responding with bad capabilities
Even Rouault
even.rouault at spatialys.com
Sun Dec 4 10:46:06 PST 2016
On mercredi 30 novembre 2016 12:55:57 CET esacree wrote:
> Question: Is it possible to get a TileLevel option added to the new GDAL
> WMTS driver?
> Reason: WMTS servers at USGS and ESRI are returning XML Capabilities with
> TileLevel 18 (Google) or TileLevel 19 (default028mm). The USGS help desk
> said that the tile servers are only serving up to Tile Level 15. The new
> GDAL WMTS driver always request data from the max TileLevel in the
> Capabilities. The mismatch between the WMTS XML capabilities and the actual
> maximum TileLevel are causing the GDAL WMTS driver requests to fail with
> Error 404 (not found).
> I have requested that they correct the WMTS XML Capabilities documents.
> Suggestion: Could a "TileLevel" parameter be added to the WMTS GDAL driver
> to limit the TileLevel to one that is available? A TileLevel parameter
> would help work around this situation.
I've just added in GDAL trunk TILEMATRIX / ZOOM_LEVEL open options and the
corresponding <TileMatrix> / <ZoomLevel> elements as child of <GDAL_WMTS>
Examples:
gdalinfo WMTSCapabilities_arcgis_usgs.xml -oo tilematrix=14
gdalinfo WMTSCapabilities_arcgis_usgs.xml,tilematrix=14
gdalinfo WMTSCapabilities_arcgis_usgs.xml -oo zoom_level=14
gdalinfo WMTSCapabilities_arcgis_usgs.xml,zoom_level=14
<GDAL_WMTS>
<GetCapabilitiesUrl>/vsimem/nominal.xml</GetCapabilitiesUrl>
<Layer>lyr1</Layer>
<Style>style=auto</Style>
<TileMatrixSet>tms</TileMatrixSet>
<TileMatrix>tm_0</TileMatrix>
<!-- or --> <ZoomLevel>0</ZoomLevel>
<DataWindow>
<UpperLeftX>-20037508.3428</UpperLeftX>
<UpperLeftY>20037508.3428</UpperLeftY>
<LowerRightX>20037508.34278254</LowerRightX>
<LowerRightY>-20037508.34278254</LowerRightY>
</DataWindow>
<BandsCount>4</BandsCount>
<Cache />
<UnsafeSSL>true</UnsafeSSL>
<ZeroBlockHttpCodes>204,404</ZeroBlockHttpCodes>
<ZeroBlockOnServerException>true</ZeroBlockOnServerException>
</GDAL_WMTS>
The difference between TILEMATRIX and ZOOM_LEVEL is that the first is the value of the
<ows:Identifier> of the <TileMatrix> in the WMTS GetCapabilities response, while the later is
the index (starting with 0) of the <TileMatrix> to consider. Sometimes they are the same
value (but sometimes the TileMatrix identifier is like EPSG:XXXX:zoom_level)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161204/a5035b87/attachment.html>
