[gdal-dev] Call for discussion on RFC 64: Triangle, Polyhedral surface and TIN
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Wed Dec 7 01:01:54 PST 2016
Even Rouault-2 wrote
> Hi,
> This is a call to discuss the proposed RFC 64: Triangle, Polyhedral
> surface and TIN
>     https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
I am wondering this part:
"GEOS methods are still used in some cases, but with the following
limitations - a Triangle is converted to a Polygon with one exterior ring;
Polyhedral Surfaces and Triangulated Surfaces are converted to
MultiPolygons?. (each Triangle in a Triangulated Surface is converted to a
Polygon as described previously)"
Does it mean presenting a TIN with two triangles as something like
As far as I know such multipolygon is not valid accorfing to the Simple
feature specification where "boundaries and may touch at only a finite
number of Points". Valid presentation would probably be to wrap polygons
into GeometryCollection. Is GEOS used in a relaxed way so that shared parts
of boundaries in MultiPolygons do not throw an error?
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Call-for-discussion-on-RFC-64-Triangle-Polyhedral-surface-and-TIN-tp5298840p5298990.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
