[gdal-dev] [gdal 2.1] ecw 5.2.1
Even Rouault
even.rouault at spatialys.com
Thu Dec 8 00:49:47 PST 2016
On jeudi 8 décembre 2016 08:28:32 CET Vincent BERNAT wrote:
> great! you're right!
> I didn't try this solution because my gcc is 5.1.0^^
Ah you're right. Looking at
https://gcc.gnu.org/onlinedocs/libstdc%2B%2B/manual/using_dual_abi.html , it seems the
version with the new ABI was indeed 5.1. I've fixed the wiki.
> Thanks a lot
> Regards,
> Vincent
> ________________________________
> De : Even Rouault <even.rouault at spatialys.com>
> Envoyé : mercredi 7 décembre 2016 16:19
> À : gdal-dev at lists.osgeo.org
> Cc : Vincent BERNAT; Jeff McKenna
> Objet : Re: [gdal-dev] [gdal 2.1] ecw 5.2.1
> On mercredi 7 décembre 2016 14:31:33 CET Vincent BERNAT wrote:
> > Thanks for reply Jeff :)
> > There are lots of things about ecw 2.3.3 which is compiling for me.
> > But not the 5.2.1 with gcc 5.1.0
> > my problem is about link...
> > In the 2.3.3 i had :
> > - libNCSEcwC.so
> > - libNCSEcw.so
> > - libNCSCnet.so
> > - libNCSCUtil.so
> > but in ECW 5.2.1, i only got :
> > - libNCSEcw.so
> > - libNCSEcwJNI.so
> > Is it enough to build it with gdal?
> > Thanks
> > Vincent
> > ________________________________________
> > De : gdal-dev <gdal-dev-bounces at lists.osgeo.org> de la part de Jeff
> > McKenna
> > <jmckenna at gatewaygeomatics.com> Envoyé : mercredi 7 décembre 2016 14:42
> > Hi Vincent,
> > You might also review the BuildHints wiki page, that we all try to keep
> > uptodate, for ECW at https://trac.osgeo.org/gdal/wiki/ECW And if you
> > notice something missing (like a tip for CentOS users) please definitely
> > edit that wiki page and add it. Hopefully this helps a little. Thanks!
> > -jeff
> > Jeff McKenna
> > MapServer Consulting and Training Services
> > http://www.gatewaygeomatics.com/
> > On 2016-12-07 9:13 AM, Vincent BERNAT wrote:
> > > Hi all,
> > > I work with gdal-2.1.0 on CentOS
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161208/d1f69422/attachment-0001.html>
