[gdal-dev] Motion: adopt RFC 64: Triangle, Polyhedral surface and TIN
Even Rouault even.rouault at spatialys.com
Fri Dec 9 03:10:25 PST 2016
There have been some good remarks, one regarding integration with GEOS that I've
taken into account in the implementation, another one regarding the possibility to
get indexed TIN that I think can be later added if needed.
So I move to adopt RFC 64: Triangle, Polyhedral surface and TIN
    https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
Starting with my +1,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161209/86dfa7b9/attachment.html>
