[gdal-dev] Convert precipitation accumulations from HDF5 to GeoTiff
Rutger
kassies at gmail.com
Tue Dec 13 02:29:55 PST 2016
Hey Paul,
If you assign the RD projection with 'a_srs', you should also assign the
'ullr' coordinates in that same projection, not in lat/lon degrees like you
do now.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Convert-precipitation-accumulations-from-HDF5-to-GeoTiff-tp5299661p5299666.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
