[gdal-dev] Primary keys are ignored in ogr2ogr when converting from Sqlite databases
César Martínez cmartinez at scolab.es
Tue Dec 13 06:36:47 PST 2016
Thank you, I was not aware of the -preserve_fid qualifier, it works as
expected when I use it.
Sorry about the noise.
César Martínez
2016-12-09 9:36 GMT+01:00 Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
> Have you tried to use the -preserve_fid qualifier ??
> ex.
> ogr2ogr -preserve_fid -f "SQLite" db2.sqlite  db.sqlite test -dsco
> SPATIALITE=YES
> Regards
> Bo Victor Thomsen
> AestasGIS
> Den 09-12-2016 kl. 00:21 skrev César Martínez:
> Hi, I am using ogr2ogr to export data from Spatialite to other formats
> (such as PostGIS or a new Spatialite db).
> The layers have an integer primary key, but this field is ignored in
> the output table, as an OGC_FID field is created which uses
> consecutive numbers, ignoring the real values of the primary key in
> the original field.
> This is quite inconvenient, as the layer is quite useless after loosing the
> PK.
> I'll provide one example to make it clearer.
> - Input data:
> CREATE TABLE test
> (id INTEGER NOT NULL PRIMARY KEY,
> name TEXT NOT NULL);
> SELECT AddGeometryColumn('test', 'the_geom', 4326, 'POINT', 'XY');
> INSERT INTO 'test' (id, name, the_geom) VALUES (1, "row1",
> GeomFromText('POINT(1.01 2.02)', 4326));
> INSERT INTO 'test' (id, name, the_geom) VALUES (3, "row3",
> GeomFromText('POINT(3.03 4.04)', 4326));
> Now we export the table using ogr2ogr:
> ogr2ogr -f "SQLite" db2.sqlite  db.sqlite test -dsco SPATIALITE=YES
> Now compare both layers:
> $ ogrinfo -q db.sqlite test
> Layer name: test
> OGRFeature(test):1
>   name (String) = row1
>   POINT (1.01 2.02)
> OGRFeature(test):3
>   name (String) = row3
>   POINT (3.03 4.04)
> $ ogrinfo -q db2.sqlite test
> Layer name: test
> OGRFeature(test):1
>   POINT (1.01 2.02)
> OGRFeature(test):2
>   POINT (3.03 4.04)
> Is this a bug or is an intended behaviour? Is there any way to workaround
> it?
> I am using GDAL version 1.11.3. It also happens when exporting to a
> different format such as PostGIS.
> Greetings,
> César Martinez
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
SCOLAB
http://scolab.es
