[gdal-dev] Convert precipitation accumulations from HDF5 to GeoTiff
Rutger
kassies at gmail.com
Tue Dec 13 07:39:34 PST 2016
Sorry, what i said makes no sense at all. You shouldn't multiply the offset
with the y-resolution, although you should take the sign, like you did. Its
a bit strange that they provide the offset as a positive value.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Convert-precipitation-accumulations-from-HDF5-to-GeoTiff-tp5299661p5299706.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
