[gdal-dev] Motion: adopt RFC 64: Triangle, Polyhedral surface and TIN
Daniel Morissette dmorissette at mapgears.com
Wed Dec 14 07:42:32 PST 2016
Thank you for the clarification. Since those changes are useful by
themselves then I change my vote to +1
Daniel
On 2016-12-14 10:19 AM, Even Rouault wrote:
> On mercredi 14 décembre 2016 10:05:46 CET Daniel Morissette wrote:
>> +0 as I'm wondering if there could be a better way to handle this, i.e.
>> it's not clear to me how useful it is to read/write those new geometry
>> types without maintaining the (topological?) relationships between the
>> objects. I am no expert with that type of data structures so my concerns
>> may be completely invalid too and I have no alternative to offer, hence
>> my +0.
> The Simple Feature model clearly doesn't maintain topological
> relationships. Topological consistency must be checked in a later stage
> with a IsValid() call for example (this also holds true for already
> handled geometry types). And if you look at some drivers that implement
> TIN currenlty like PostGIS or GML, they are based on the Simple Feature
> model as well. Only shapefile/filegdb has something a bit stronger with
> shared nodes.
> I think that support for topological geometries would be a completely
> different concept to be added in OGR. Would require management of nodes,
> edges and faces, and conversions between simple feature geometries and
> topogeometries. I had some preliminary discussions about that with an
> interested party in the past but they didn't go further.
> In the current state of things, the TIN support should be hopefully good
> enough for conversions between PostGIS, GML, DXF and shapefile/filegdb.
> Even
>> Daniel
>> On 2016-12-13 1:13 PM, Even Rouault wrote:
>> > On vendredi 9 décembre 2016 12:10:25 CET Even Rouault wrote:
>> >> Hi,
>> >> There have been some good remarks, one regarding integration with GEOS
>> > that
>> >> I've taken into account in the implementation, another one
> regarding the
>> >> possibility to get indexed TIN that I think can be later added if
> needed.
>> >> So I move to adopt RFC 64: Triangle, Polyhedral surface and TIN
>> >> https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
>> >> Starting with my +1,
>> > Friendly remainder that this motion is under vote.
>> > Even
>> > Spatialys - Geospatial professional services
>> > http://www.spatialys.com
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Daniel Morissette
http://www.mapgears.com/
T: +1 418-696-5056 #201
http://evouala.com/ - Location Intelligence Made Easy
