[gdal-dev] GDAL doesn't read GeoTiff .msk mask file
Even Rouault
even.rouault at spatialys.com
Mon Dec 19 04:38:04 PST 2016
Nikolai,
> I’ve got an 8-bit 3-band (RGB) GeoTiff file created in ArcGIS and it has a
> mask file (myfile.tif.msk) along with it, indicating which pixels have
> "nodata" value. When viewing it in ArcMap, I get “nodata” for masked
> pixels. But when viewing in QGIS, I get an unmasked raster and masked
> pixels return pixel values of R G and B bands. Gdalinfo doesn’t return a
> .tif.msk file in a list of dataset files (however it does return .aux.xml).
If you look at a valid .msk file generated by GDAL, you'll see INTERNAL_MASK_FLAGS_x
metadata item being reported. If there's no INTERNAL_MASK_FLAGS_x for band x,
then GDAL will ignore the .msk file for this band.
$ gdalinfo with_mask.tif.msk
Driver: GTiff/GeoTIFF
Files: with_mask.tif.msk
Size is 50, 50
Coordinate System is `'
Metadata:
INTERNAL_MASK_FLAGS_1=2
INTERNAL_MASK_FLAGS_2=2
INTERNAL_MASK_FLAGS_3=2
Image Structure Metadata:
COMPRESSION=DEFLATE
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 50.0)
Upper Right ( 50.0, 0.0)
Lower Right ( 50.0, 50.0)
Center ( 25.0, 25.0)
Band 1 Block=50x50 Type=Byte, ColorInterp=Gray
The 2 here comes from the following GMF_ enumeration and so means that it
is a mask valid for all the bands of the dataset.
/** Flag returned by GDALGetMaskFlags() to indicate that all pixels are valid */
#define GMF_ALL_VALID 0x01
/** Flag returned by GDALGetMaskFlags() to indicate that the mask band is
* valid for all bands */
#define GMF_PER_DATASET 0x02
* an alpha band */
#define GMF_ALPHA 0x04
* computed from nodata values */
#define GMF_NODATA 0x08
You can add this flag with gdal_translate :
gdal_translate my_invalid.tif.msk my_valid.tif.msk -co COMPRESS=DEFLATE \
-mo INTERNAL_MASK_FLAGS_1=2 -mo INTERNAL_MASK_FLAGS_2=2 -mo INTERNAL_MASK_FLAGS_3=2
> My goal is to add an internal mask band to GeoTiff files, so everything is
> packed within one file, and create a VRT mosaic afterwards. Another option
> is to use .tif.msk file as is. But I can’t find any options to
> gdal_translate, or gdalinfo to force gdal use the mask file. There isn’t
> much gdal documentation regarding .msk files.
See:
https://trac.osgeo.org/gdal/wiki/rfc15_nodatabitmask
http://gdal.org/frmt_gtiff.html ("Internal nodata masks" section)
But it is true that the details of .msk files were not mentionned. I've just
improved that withhttps://trac.osgeo.org/gdal/changeset/36955 and
https://trac.osgeo.org/gdal/wiki/rfc15_nodatabitmask?action=diff&version=16&old_version=15
> How can I read mask file with
> gdal and convert my initial RGB GeoTiff to a GeoTiff with a mask band from
> it?
Once your mask is fixed to be recognized as explain above, you can create an
internal mask with:
gdal_translate in_with_external_mask.tif out_with_internal_mask.tif --config GDAL_TIFF_INTERNAL_MASK YES
But note that QGIS does not handle GDAL mask band currently. You'll have to
transform the binary mask band as an alpha channel instead
gdal_translate rgb_with_mask.tif rgba.tif -b 1 -b 2 -b 3 -b mask
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161219/3a2d377d/attachment.html>
