[gdal-dev] Problem when creating overviews for large input files with gdaladdo
Even Rouault
even.rouault at spatialys.com
Mon Dec 19 13:26:14 PST 2016
Armin,
This is a "well known" performance issue with the geotiff driver / libtiff when switching back
and forth between IFD (image file directories). At ~ 75%, you start generating overview
factor 4 and that implies switching regularly between the one previously computed (read
operations) and the new one (write operations). Each time you switch, you need to read and
write the TileOffsets and TileByteCounts tags (those can be 10's of megabytes large on huge
file, and are the root cause for the performance problem). With infinite patience, this would
eventually complete.
A trick you can use is :
gdaladdo -ro --config COMPRESS_OVERVIEW LZW INPUT_FILE 2
gdaladdo -ro --config COMPRESS_OVERVIEW LZW INPUT_FILE.ovr 2
gdaladdo -ro --config COMPRESS_OVERVIEW LZW INPUT_FILE.ovr.ovr 2
gdaladdo -ro --config COMPRESS_OVERVIEW LZW INPUT_FILE.ovr.ovr.ovr 2
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161219/b6d21186/attachment.html>
