[gdal-dev] Read error on large VRT files
Even Rouault even.rouault at spatialys.com
Wed Dec 21 01:49:59 PST 2016
On mercredi 21 décembre 2016 10:29:27 CET Armin Burger wrote:
> Margherita
> thanks, now that you say this, I remeber a special GDAL option
> "GDAL_MAX_DATASET_POOL_SIZE" which by default is 100. The operating system
> limit itself is high enough on our server (65k). When running the
> processing again with less memory cache (and hence likely less concurrent
> opened files) it worked without errors. I will set this GDAL option and see
> if I ever run into this errors again.
On which option did you play exactly ?
The TIFF error you get is a rather low level one (really trying to read a range of bytes from
a file), and I can't explain why GDAL options would play a role on it.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161221/7391fb13/attachment.html>
