[gdal-dev] Call for discussion about RFC 61: Support for measures in geometries
Even Rouault even.rouault at spatialys.com
Wed Feb 3 07:23:37 PST 2016
Le mercredi 03 février 2016 16:16:17, Ari Jolma a écrit :
> >> (I see
> >> it doesn't have CPL_DLL) I don't think there is a ogr_internal.h, maybe
> >> there should be and move this function there?
> >  From the header
> > """ * Purpose:  Some private helper functions and stuff for OGR
> > implementation."""
> > (and the _p suffix meaning protected/private)
> > And as you noticed this symbol is not exported, so it can only be used by
> > in- tree code.
> Perfectly usable in Linux :)
Not if you ./configure --with-hide-internal-symbols  (which some distro such as
UbuntuGIS use)
http://www.spatialys.com
