[gdal-dev] Fork Yeah!
Aaron Boxer boxerab at gmail.com
Wed Feb 3 12:22:43 PST 2016
Hi Damian,
> The use of AGPL means that your OpenJPEG fork will not be used for
> commercial projects and any enhancements you make will not make there way
> into OpenJPEG.
Correct.
> You may have a good reason for choosing this licence and as such it is
> your choice.
Yes.
> Either way good luck.
Thank you.
Cheers,
Aaron
> On 3 February 2016 at 19:28, Aaron Boxer <boxerab at gmail.com> wrote:
>> Dear GDAL Developers,
>> I am developing a new open source JPEG 2000 toolkit, based on OpenJPEG.
>> It is a drop-in replacement for OpenJPEG, but features:
>> - fast precinct-level decode
>> - lower memory usage
>> - better performance - currently it is roughly 1/3 the perf of Kakadu,
>> (tested on windows), and I am hoping to get it down to around 1/2
>> I was originally hoping to merge these changes into OpenJPEG. For a
>> number of reasons, I decided to start a new project instead.  One of my
>> main motivations is the fact that  OpenJPEG is a reference implementation,
>> designed for correctness and portability. My main interest is performance.
>> I have ported the code to C++14, so developers get access to all of the
>> modern C++ goodness such as class hierarchies, lambdas, threading library,
>> exceptions, standard template library, etc.
>> Gone is support for older compilers, including VS 2010.
>> The code is licensed under the AGPL, to ensure that all code
>> modifications get contributed back to the community.
>> It you find this useful, please visit
>> https://github.com/GrokImageCompression/ronin
>> For those who need a more permissive license, or who prefer using the
>> reference implementation, there is always good old OpenJPEG.
>> Kind Regards,
>> Aaron
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160203/8b3b186a/attachment.html>
