Le jeudi 04 février 2016 10:30:55, Martin Landa a écrit :
> Hi,
> 2016-02-04 0:00 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> >> Have a look at the "Getting XML attributes as OGR fields" section of
> >> http://gdal.org/drv_gml.html
> > oh, thanks, I overlooked this part. Ma
> after various experiments I still must miss something. The input data:
> <ucastnici>
> <uca id="0" />
> <uca id="1" />
> </ucastnici>
> GFS:
> <GMLFeatureClassList>
> <!-- ucastnici -->
> <GMLFeatureClass>
> <Name>ucastnici</Name>
> <ElementPath>ucastnici|uca</ElementPath>
> <GeometryType>100</GeometryType>
> <PropertyDefn>
> <Name>id</Name>
> <ElementPath>@id</ElementPath>
> <Type>Integer</Type>
> </PropertyDefn>
> </GMLFeatureClass>
> </GMLFeatureClassList>
> I tried:
> <ElementPath>uca at id</ElementPath>
> But the attribute is still null.
> When I try
Ah, you want to get an attribute of the root element of the feature ? Hum,
from a quick test with
<?xml version="1.0" encoding="utf-8" ?>
<ogr:FeatureCollection
xmlns:ogr="http://ogr.maptools.org/"
xmlns:gml="http://www.opengis.net/gml">
<gml:featureMember>
<ogr:poly fid="poly.0" foo="bar">
<baz baw="yeah"/>
</ogr:poly>
</gml:featureMember>
</ogr:FeatureCollection>
and
<GMLFeatureClass>
<Name>poly</Name>
<ElementPath>poly</ElementPath>
<PropertyDefn>
<Name>foo</Name>
<ElementPath>@foo</ElementPath>
<Type>String</Type>
</PropertyDefn>
<PropertyDefn>
<Name>baw</Name>
<ElementPath>baz at baw</ElementPath>
<Type>String</Type>
</PropertyDefn>
</GMLFeatureClass>
it looks indeed that the @xxxx syntax isn't supported on the root node. It
could likely be implemented
> then I am still getting 0 features.
> Thanks, Martin
http://www.spatialys.com
