[gdal-dev] support for Czech Exchange Format for Land Consolidation
Even Rouault even.rouault at spatialys.com
Thu Feb 4 01:51:48 PST 2016
Le jeudi 04 février 2016 10:46:24, Martin Landa a écrit :
> Hi,
> 2016-02-04 10:42 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > it looks indeed that the @xxxx syntax isn't supported on the root node.
> > It could likely be implemented
> please could you tell where I should take a look?
Should be added in GMLHandler::startElementDefault(), probably using
DealWithAttributes(). Admitedly this code is non-trivial.
> Thanks, Ma
http://www.spatialys.com
