[gdal-dev] Building multiple versions of GDAL from the same tree...
Kurt Schwehr schwehr at gmail.com
Mon Feb 8 08:11:33 PST 2016
Hi Carl,
Adding "VPATH" support for the autoconf setup has been on my wish list of
things to have in the current build system.  It will take a bit of
patching.  And hasn't made it up to the top of my priority list (and won't
for a while)
So the answer is:  Not yet.
If anyone wants to take a stab at it and post the patch, I'd be happy to
give it a look and test it.
-kurt
On Mon, Feb 8, 2016 at 7:01 AM, Carl Godkin <cgodkin at gmail.com> wrote:
> Hi,
> With a shiny new version of GDAL now available (thanks!), I'm wondering
> about a problem with the builds that I always have but have never asked
> about before.
> Since I need to build several Linux variants of various third party
> libraries, I can usually persuade "configure" and make to work from a
> sub-directory like this:
> cd library && mkdir version1 && cd version1
> ../configure options...
> make
> followed by
> cd library && mkdir version2 && cd version2
> make
> and
> cd library && mkdir version3 && cd version3
> make
> so that I end up with three completely independent builds of the library
> in the sub-directories.
> I've never been able to get this sort of build to work with GDAL however.
> I know configure has a million options so I may have overlooked a trick for
> this.
> Has anyone else been successful trying this with GDAL?
> Thanks,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160208/d40eecfe/attachment.html>
