[gdal-dev] Native library load failed while using gdal maven dependency - UnsatisfiedLinkError
Justin Deoliveira
jdeolive at gmail.com
Tue Feb 9 12:27:04 PST 2016
Looks like you have everything configured properly. I have seen reports
from users having issue with using a gdal jar compiled on a different
system. I’ve never seen that personally but from what I understand the
solution in that case was to just compile the java (and the rest of the
gdal libs) themselves locally.
On Tue, Feb 9, 2016 at 12:58 PM ssaniev <ssaniev at gmail.com> wrote:
> Hi Justin,
> Coding in java Windows7/Eclipse/spring/maven.
> *As told before, added dependency to pom, and see the gdal-2.0.0.jar in
> maven dependencies and able to import to my java class.*
> <dependency>
> <groupId>org.gdal</groupId>
> <artifactId>gdal</artifactId>
> <version>2.0.0</version>
> </dependency>
> I downloaded the libraries from here:
> http://download.gisinternals.com/sdk/downloads/release-1800-x64-gdal-1-11-3-mapserver-6-4-2.zip
> unzippped... and added the both paths below to my environment PATH
> variable:
> ..\Downloads\release-1800-x64-gdal-1-11-3-mapserver-6-4-2\bin
> ..\Downloads\release-1800-x64-gdal-1-11-3-mapserver-6-4-2\bin\gdal\java
> Created another environment variable
> GDAL_DATA=..\Downloads\release-1800-x64-gdal-1-11-3-mapserver-6-4-2\bin\gdal-data
> Inside Eclipse, added a VM argument to my project runtume:
> -Djava.library.path="..\workspace\GISDataDirectory\release-1800-x64-gdal-1-11-3-mapserver-6-4-2\bin\gdal\java\;${env_var:PATH}"
> *And after all this, I am getting a different related error:*
> Native library load failed.
> java.lang.UnsatisfiedLinkError:
> ..\workspace\GISDataDirectory\release-1800-x64-gdal-1-11-3-mapserver-6-4-2\bin\gdal\java\gdaljni.dll:
> The specified procedure could not be found
> nested exception is java.lang.UnsatisfiedLinkError:
> org.gdal.gdal.gdalJNI.VersionInfo__SWIG_1()Ljava/lang/String;] with root
> cause
> What am I missing here?
> http://osgeo-org.1560.x6.nabble.com/Native-library-load-failed-while-using-gdal-maven-dependency-UnsatisfiedLinkError-tp5249728p5249767.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160209/31e4d7f5/attachment.html>
