[gdal-dev] RFC 61: Call for vote on adoption
Ari Jolma
ari.jolma at gmail.com
Wed Feb 10 03:26:59 PST 2016
One more issue came up.
Shapefiles, which have Z will also have M, at least a placeholder for it.
Having shapefiles as XYZM always in that case may be problematic.
It is possible to use the open options SHPT=type to override the
default. We could have Z => XYZ as default for backwards compatibility
and require open option for Z => XYZM.
Ari
09.02.2016, 17:07, Ari Jolma kirjoitti:
> I declare this motion passed with +1 from Even, Tamas, Jukka and
> Daniel and no -1.
> I'll commit soon the changes to the core and then later the drivers:
> memory, shape and pg. The goal is to keep the travis test build passing.
> Ari
> 05.02.2016, 10:04, Ari Jolma kirjoitti:
>> I'd like to ask the PSC and others to vote on adopting RFC 61:
>> Support for measured geometries.
>> The draft RFC is at
>> https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
>> and a draft implementation is at
>> https://github.com/ajolma/GDAL-XYZM
>> which is tested at
>> https://travis-ci.org/ajolma/GDAL-XYZM
>> (the test #34, which passed, was the so far last one after core
>> changes with unchanged autotests and a rather comprehensive set of
>> WKT tests in the Perl tests directory)
>> This is seemingly a small change but it is at the heart of OGR so it
>> has some important implications. The only backwards incompatibilities
>> that have appeared so far are with some drivers, for example
>> shapefile, which can be lessened with, e.g., open options.
>> Best,
>> Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160210/892edd10/attachment.html>
