[gdal-dev] RFC 61: Call for vote on adoption
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Wed Feb 10 04:04:38 PST 2016
Ari Jolma <ari.jolma <at> gmail.com> writes:
> One more issue came up.
> Shapefiles, which have Z will also have M, at least a placeholder
> for it.
> Having shapefiles as XYZM always in that case may be problematic.
> It is possible to use the open options SHPT=type to override the
> default. We could have Z => XYZ as default for backwards
> compatibility and require open option for Z => XYZM.
> Ari09.02.2016, 17:07, Ari Jolma kirjoitti:
I noticed your changeset and I was just reading the shapefile specification.
I never knew that there are no separate XYZ and XYZM shapetypes. I also
believe I have never met a shapefile that really contains XYZM data.
I agree that the default should be to convert such shapefiles to XYZ instead
of XYZM. That would affect shapetype values
11 PointZ
13 PolyLineZ
15 PolygonZ
18 MultiPointZ
-Jukka Rahkonen-
