[gdal-dev] RFC 61: Call for vote on adoption
Mike Toews
mwtoews at gmail.com
Wed Feb 10 16:00:54 PST 2016
On 11 February 2016 at 02:05, Even Rouault <even.rouault at spatialys.com> wrote:
> Would someone looking at this discussion and having access to ESRI software be
> willing to generate tiny (meaning just one single shape, with the smallest
> number of vertices) shapefiles of type PointZ, ArcZ, PolygonZ and MultiPointZ,
> and *without* M values ? So as to enhance the test suite and see in particular
> which value is set exactly as the nodata value in the M component
Done, see https://trac.osgeo.org/gdal/attachment/wiki/MeasuredGeometriesInDrivers/
I created two geometry examples per shapefile, and added an "Expected"
attribute to describe the WKT of the expected geometry. While the M
values were editable (despite not requesting this creation option in
ArcCatalog), I left these as "NaN".
