[gdal-dev] RFC 61: Call for vote on adoption
Ari Jolma
ari.jolma at gmail.com
Fri Feb 12 02:26:46 PST 2016
I've fixed this so that currently all tests pass (at least locally).
Now Shapefiles, which are created XY come back as XY, XYM as XYM, XYZ as
XYZ, and XYZM as XYZM. Also one should be able to set the required
coordinate combination using parameters - that's not comprehensively
tested however.
There are still a couple of fixme's in the code (shape2ogr.cpp), writing
a shape should take into account the requested coordinate combination
and whether to skip Ms or write them as "no data" (value < 1038
according to the doc).
I changed the code for OGRFeature::SetGeomFieldDirectly to set or unset
the geometry M or Z coordinates depending on the geometry field type of
the feature. That's somewhat bold but the way I did it at least did not
break anything in the tests.
Ari
10.02.2016, 13:26, Ari Jolma kirjoitti:
> One more issue came up.
> Shapefiles, which have Z will also have M, at least a placeholder for it.
> Having shapefiles as XYZM always in that case may be problematic.
> It is possible to use the open options SHPT=type to override the
> default. We could have Z => XYZ as default for backwards compatibility
> and require open option for Z => XYZM.
> Ari
> 09.02.2016, 17:07, Ari Jolma kirjoitti:
>> I declare this motion passed with +1 from Even, Tamas, Jukka and
>> Daniel and no -1.
>> I'll commit soon the changes to the core and then later the drivers:
>> memory, shape and pg. The goal is to keep the travis test build passing.
>> Ari
>> 05.02.2016, 10:04, Ari Jolma kirjoitti:
>>> I'd like to ask the PSC and others to vote on adopting RFC 61:
>>> Support for measured geometries.
>>> The draft RFC is at
>>> https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
>>> and a draft implementation is at
>>> https://github.com/ajolma/GDAL-XYZM
>>> which is tested at
>>> https://travis-ci.org/ajolma/GDAL-XYZM
>>> (the test #34, which passed, was the so far last one after core
>>> changes with unchanged autotests and a rather comprehensive set of
>>> WKT tests in the Perl tests directory)
>>> This is seemingly a small change but it is at the heart of OGR so it
>>> has some important implications. The only backwards
>>> incompatibilities that have appeared so far are with some drivers,
>>> for example shapefile, which can be lessened with, e.g., open options.
>>> Best,
>>> Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160212/ad1e8ff4/attachment.html>
