[gdal-dev] gdal_translate crop tiff (cmyk)
Paulo Pires
paulopires16 at gmail.com
Sat Feb 13 03:59:43 PST 2016
Hello
I use the command *gdal_translate *with *-projwin* option to crop a tiff
image but I lose the CMYK SOURCE_COLOR_SPACE
The croped image is in RGB :/
*D:\raster>gdalinfo D:\raster\cmyk.tif*
Driver: GTiff/GeoTIFF
Files: D:\raster\cmyk.tif
D:\raster\cmyk.tfw
Size is 11568, 20061
Coordinate System is `'
Origin = (191513.750000000000000,516826.250000000000000)
Pixel Size = (12.500000000000000,-12.500000000000000)
Metadata:
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
TIFFTAG_XRESOLUTION=508
TIFFTAG_YRESOLUTION=508
Image Structure Metadata:
COMPRESSION=PACKBITS
INTERLEAVE=BAND
SOURCE_COLOR_SPACE=CMYK
Corner Coordinates:
Upper Left ( 191513.750, 516826.250)
Lower Left ( 191513.750, 266063.750)
Upper Right ( 336113.750, 516826.250)
Lower Right ( 336113.750, 266063.750)
Center ( 263813.750, 391445.000)
Band 1 Block=11568x1 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=11568x1 Type=Byte, ColorInterp=Green
Band 3 Block=11568x1 Type=Byte, ColorInterp=Blue
Band 4 Block=11568x1 Type=Byte, ColorInterp=Alpha
*D:\raster>gdalinfo D:\raster\cmyk_crop.tif*
Files: D:\raster\cmyk_crop.tif
D:\raster\cmyk_crop.tfw
Size is 80, 800
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Lower Left ( 191513.750, 506826.250)
Upper Right ( 192513.750, 516826.250)
Lower Right ( 192513.750, 506826.250)
Center ( 192013.750, 511826.250)
Band 1 Block=80x25 Type=Byte, ColorInterp=Red
Band 2 Block=80x25 Type=Byte, ColorInterp=Green
Band 3 Block=80x25 Type=Byte, ColorInterp=Blue
Band 4 Block=80x25 Type=Byte, ColorInterp=Alpha
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-translate-crop-tiff-cmyk-tp5250378.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
