[gdal-dev] Read data without reading 'null data'
Even Rouault even.rouault at spatialys.com
Fri Feb 19 02:13:28 PST 2016
Le vendredi 19 février 2016 10:48:50, jramm a écrit :
> We are storing large raster datasets (~500,000 x 500,000) in geotiff files.
> The array data is typically very sparse (density is 0.02% or less) and
> compression greatly reduces the geotiff size.
> However, when processing data we read the data in chunks, which are
> automatically decompressed..this means we are often reading in large areas
> of no data and 'skipping' them.
> Is there a way to only read data with values so we may apply the processing
> to these cells, and write them back out, skipping the no data? I guess this
> would be equivalent to just not decompressing?
The GTiff driver supports the concept of "sparse" files, which is I think a
GDAL-specific extension, of how tiles and strips are indexed in TIFF. Basically
if the byte size of a given block is marked as 0, it is interpreted as not
physically present in the file and, when the block is read through the GDAL
API, the pixels are initialized to 0 or the nodata value.
Currently sparse files can only be generated with the Create() API with the
SPARSE_OK creation option, and by not writting any data (not even 0 or the
nodata value) in the blocks you don't want to be serialized. Consequently
using gdal_translate or gdalwarp will not produce the desired effect. Although
that could be certainly improved.
On the reading side, in recent releases (2.0 I think), you can query the
BLOCK_SIZE_{blockxoff}_{blockyoff} metadata item in the TIFF metadata domain to
know if a block is present or not (return will be NULL for absent)
Even
> http://osgeo-org.1560.x6.nabble.com/Read-data-without-reading-null-data-tp
> 5251626.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
