[gdal-dev] vector drivers with mixed topology types in a single layer?
Michael Sumner mdsumner at gmail.com
Sun Feb 21 15:09:03 PST 2016
On Wed, 17 Feb 2016 at 23:24 Michael Sumner <mdsumner at gmail.com> wrote:
> On Wed, 17 Feb 2016 11:18 pm Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le mercredi 17 février 2016 12:25:24, Michael Sumner a écrit :
>> > Hi there, is there an easy way to discover which formats allow mixing of
>> > vector types in a single layer?
>> No, there is no such driver metadata currently. You need to open the
>> dataset
>> and query the layer geometry type. If it is unknown, then it allows mix of
>> geometry types.
>> > I.e. a single layer MapInfo file with points, lines, and polygons - I
>> know
>> > there is MapInfo (tab) and MapInfo (mif) and GeoJSON,
>> > I'd also like to know what drivers can present as a single data set but
>> > with these types separated into different layers, like SDTS.
>> > I consider the multiple shapefiles in one folder feature to be a
>> somewhat
>> > different, third case.
>> From the point of view of the OGR API, a directory of shapefile = a
>> dataset
>> with several layers
>> > Is there a clear way to categorize these three kinds, and classify all
>> > existing drivers this way?
>> I think there are 2 orthogonal isssues :
>> - which drivers support mixed of geometry type in a single layer
>> - which drivers support multiple layers in a dataset (in general, datasets
>> that support multiple layers do not set a constraint on the unicity of the
>> geometry type among layers)
>> And perhaps to address your shapefile case :
>> - which drivers support only opening a file
>> - which drivers support only opening a directory
>> - which drivers support both
>> - which drivers are not file related (already addressed by checking if the
>> GDAL_DMD_CONNECTION_PREFIX / "DMD_CONNECTION_PREFIX" metadata item is
>> present.
>> Was added in GDAL 2.0)
>> > Am I on the right track, or is it more complicated?
>> > Cheers, Mike.
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Thank you Even, very helpful.
> Cheers, Mike
Is there much discussion recorded about this issue in general? I find it
odd that QGIS does not allow mixing - at all - given that OGR supports it.
I found this:
http://gis.stackexchange.com/questions/89423/combining-different-geometry-types-into-same-feature-class
I'm interested in GDAL-specific discussions, or any packages that use GDAL
that allow this.
The now defunct  Eonfusion project supported this mixing with a
spatial-primitives-based data model (I worked on the project it for a
time).
FWIW I'm a long-term Manifold user so I take this capability for granted:
 http://www.georeference.org/doc/drawings.htm
I'm exploring geometry models in R that allow both traditional "features"
alongside triangulated meshes and other primitves-based structures.  This
is a much better fit for database-aligned data sets, and obviously mixed
geometry is an obvious need for query-based GIS.
Keen to see any links to discussions that folks might remember, or that are
active currently.
Cheers, Mike.
> Dr. Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> 203 Channel Highway
> Kingston Tasmania 7050 Australia
Dr. Michael Sumner
203 Channel Highway
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160221/88a6a6cd/attachment.html>
