[gdal-dev] libkml driver get document name
Even Rouault
even.rouault at spatialys.com
Tue Feb 23 15:53:59 PST 2016
Le mardi 23 février 2016 14:50:35, jan vaillant a écrit :
> Hi list,
> I am reading a zipped kml with gdal's libkml driver. I am trying to access
> the name tag of the document:
> <kml>
> <Document>
> <name>a_name</name>
I did a quick testing It appears that the driver will report a <name> as the
layer name only if it inside a <Folder> tag, but not as a direct child of
<Document>
> If I look at the source code I can see a way to set those options here for
> writing kml
> void OGRLIBKMLDataSource::SetCommonOptions(ContainerPtr poKmlContainer,
> char** papszOptions)
> const char* pszName = CSLFetchNameValue(papszOptions, "NAME");
> if( pszName != NULL )
> poKmlContainer->set_name(pszName);
> but I cant find a way to read the options. ogrLayer->GetName() returns the
> file name not the <name>a_name</name> element. Any ideas?
> Thank you
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
