[gdal-dev] osmconf.ini
Frank Broniewski
frank.broniewski at gmail.com
Wed Feb 24 04:28:05 PST 2016
Ok, I tested the ogrinfo example given by Even with my created excerpt, and
there seems to be no object with the ID 2827792. Now I wanted to try the
europe extract, which is the source of my own extracts, but ogrinfo gives
me lots of results where the -where clause does not fit. Any ideas? Here's
my command:
ogrinfo europe-2016-02-12T20-14-02Z.osm.pbf -where "osm_id = '2827792'"
-geom=no -al -q --config OSM_USE_CUSTOM_INDEXING NO --config
OGR_INTERLEAVED_READING YES
Some output snips:
tunnel (String) = (null)
maxspeed (String) = (null)
ref (String) = (null)
railway (String) = (null)
width (String) = (null)
other_tags (String) = (null)
OGRFeature(lines):4000402
osm_id (String) = 4000402
name (String) = (null)
highway (String) = unclassified
waterway (String) = (null)
aerialway (String) = (null)
barrier (String) = (null)
man_made (String) = (null)
oneway (String) = (null)
bridge (String) = (null)
OGRFeature(lines):4000405
osm_id (String) = 4000405
name (String) = Post Mill Close
highway (String) = residential
OGRFeature(lines):4000406
osm_id (String) = 4000406
name (String) = Ashmere Grove
I had to add the last config option because ogrinfo told me so ;)
2016-02-22 8:14 GMT+01:00 Frank Broniewski <frank.broniewski at gmail.com>:
> Mh, maybe I should have a look at my data. I downloaded a europe extract
> from geofabrik and used osmconvert and osmupdate to cut out a piece from
> europe and to update it. I am still sick, influenza caught me, but maybe in
> the afternoon I find some time to check wether there is something missing
> from my selfmade extract.
> 2016-02-21 8:02 GMT+01:00 Andre Joost <andre+joost at nurfuerspam.de>:
>> Am 20.02.2016 um 16:18 schrieb Even Rouault:
>>> Frank,
>>> I clicked on the "Export" button on the view centered on
>>> http://www.openstreetmap.org/relation/2827792 , and ran
>>> $ ogrinfo ~/Téléchargements/map.osm multilinestrings \
>>> -where "osm_id = '2827792'" -geom=no -al -q \
>> Based on that, I get a shapefile of the route with
>> ogr2ogr -overwrite route-export.shp map-export.osm -where "osm_id =
>> '2827792'" -progress --config OSM_USE_CUSTOM_INDEXING NO -skipfailures
>> HTH,
>> André Joost
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Waldhölzbacher Str. 51
> 66679 Losheim am See
> 06872 922 1051
> 0177 30 21 791
> [Ich bin auch bei XING und LinkedIn zu finden]
06872 922 1051
0177 30 21 791
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160224/355ed474/attachment-0001.html>
