[gdal-dev] libkml driver get document name
Damian Dixon damian.dixon at gmail.com
Wed Feb 24 09:30:30 PST 2016
I've been meaning to submit a patch for awhile to libkml driver but have
not had time to do so.
The fix is a one line change highlighted below:
int OGRLIBKMLDataSource::OpenKml (
    const char *pszFilename,
    int bUpdate )
    std::string oKmlKml;
    char szBuffer[1024+1];
    VSILFILE* fp = VSIFOpenL(pszFilename, "rb");
    if (fp == NULL)
        CPLError ( CE_Failure, CPLE_OpenFailed,
                   "Cannot open %s", pszFilename );
        return FALSE;
    int nRead;
    while ((nRead = VSIFReadL(szBuffer, 1, 1024, fp)) != 0)
        try
            oKmlKml.append(szBuffer, nRead);
        catch(std::bad_alloc& e)
            VSIFCloseL(fp);
            return FALSE;
    OGRLIBKMLPreProcessInput(oKmlKml);
    VSIFCloseL(fp);
    CPLLocaleC  oLocaleForcer;
    /***** create a SRS *****/
    OGRSpatialReference *poOgrSRS =
        new OGRSpatialReference ( OGRLIBKMLSRSWKT );
    /***** parse the kml into the DOM *****/
    std::string oKmlErrors;
    ElementPtr poKmlRoot = kmldom::Parse ( oKmlKml, &oKmlErrors );
    if ( !poKmlRoot ) {
                   "ERROR Parseing kml %s :%s",
                   pszFilename, oKmlErrors.c_str (  ) );
        delete poOgrSRS;
        return FALSE;
    /***** get the container from root  *****/
    if ( !( m_poKmlDSContainer = GetContainerFromRoot ( m_poKmlFactory,
poKmlRoot ) ) ) {
                   "ERROR Parseing kml %s :%s %s",
                   pszFilename, "This file does not fit the OGR model,",
                   "there is no container element at the root." );
        delete poOgrSRS;
        return FALSE;
    m_isKml = TRUE;
    /***** get the styles *****/
    ParseStyles ( AsDocument ( m_poKmlDSContainer ), &m_poStyleTable );
    /***** parse for layers *****/
    int nPlacemarks = ParseLayers ( m_poKmlDSContainer, poOgrSRS );
    /***** if there is placemarks in the root its a layer *****/
*    if ( nPlacemarks ) {*   //
<------------------------------------------------------------------------------------------This
line
        AddLayer ( CPLGetBasename ( pszFilename ),
                   poOgrSRS, wkbUnknown,
                   this, poKmlRoot, m_poKmlDSContainer, pszFilename, FALSE,
bUpdate, 1 );
    delete poOgrSRS;
    return TRUE;
Regards
Damian
On 24 February 2016 at 17:00, Jan Vaillant <jvail at gmx.de> wrote:
> On 02/24/2016 12:53 AM, Even Rouault wrote:
>> Le mardi 23 février 2016 14:50:35, jan vaillant a écrit :
>>> Hi list,
>>> I am reading a zipped kml with gdal's libkml driver. I am trying to
>>> access
>>> the name tag of the document:
>>> <kml>
>>>    <Document>
>>>      <name>a_name</name>
>> I did a quick testing It appears that the driver will report a <name> as
>> the
>> layer name only if it inside a <Folder> tag, but not as a direct child of
>> <Document>
> Yes, thank you. I tried the kml driver as well and it stores the
> Document/name and makes it available with layer.getName().
> Bye
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160224/91c97d00/attachment.html>
