[gdal-dev] gdalwarp and the -wm switch
Neumann, Andreas
a.neumann at carto.net
Thu Feb 25 05:53:08 PST 2016
I wonder if there are any recommendations regarding the
-wm _memory_in_mb setting._
Should I use this setting or just ignore it? My machines usually have
plenty of RAM. Do I have to increase this value if I want to utilize the
available RAM or is this done automatically and this settings exists to
restrict the used amoung of RAM?
I am just trying to understand what this setting means. What is the
default value for this setting if not set?
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160225/9bbe575a/attachment.html>
