[gdal-dev] Motion: Committer Status for Lucian Plesea
Lucian Plesea LPlesea at esri.com
Fri Feb 26 12:30:42 PST 2016
Thanks, it worked!
Lucian
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, February 26, 2016 11:42 AM
To: gdal-dev at lists.osgeo.org
Cc: Lucian Plesea
Subject: Re: [gdal-dev] Motion: Committer Status for Lucian Plesea
I declare this motion passed with +1 from KurtS, FrankW, JukkaR, DanielM and myself.
Lucian, I've just granted you commit rights. To check that it works, could you add yourself to the COMMITERS file at the root of gdal/ ?
> Dear PSC,
> Lucian is the maintainer of the MRF (Meta Raster Format) driver who
> has existed as an out-of-tree driver and whose main repository is at
> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_nasa-2
> Dgibs_mrf&d=CwIFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=ZN_tL2S6ZCPdMt_gpID_yQ&m
> =U35-EL9da2D88Q1ivdtgy41dmOuKjNtOfujc4BzIhQs&s=YzUEOY-QH-dTiTVIhrKFONY
> dAH8DR3pK0QU24FQFEZQ&e=  . Recently I've worked with him to get the
> driver also integrated in the GDAL tree itself, and he merged back the
> changes in the above mentionned repository, so that both code base are
> now in sync. For the future, it would be convenient if Lucian could directly maintain the GDAL copy directly and keep in sync both repositories, so I motion to grant him commit rights. Lucian scope of interest also includes the WMS driver.
> I'll start the voting with:
> +1 Even
> Lucian,
> Please, could you answer to this message and state that you have read
> and agreed to the committer guidelines as outlined in the RFC3 (
> https://urldefense.proofpoint.com/v2/url?u=http-3A__trac.osgeo.org_gda
> l_wiki_rfc3-5Fcommiters&d=CwIFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=ZN_tL2S6ZC
> PdMt_gpID_yQ&m=U35-EL9da2D88Q1ivdtgy41dmOuKjNtOfujc4BzIhQs&s=WAhc98qI0
> 6a7hMEvJm_DuvgxZR-JNHfqW4JT4awnWwc&e=  )
Spatialys - Geospatial professional services https://urldefense.proofpoint.com/v2/url?u=http-3A__www.spatialys.com&d=CwIFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=ZN_tL2S6ZCPdMt_gpID_yQ&m=U35-EL9da2D88Q1ivdtgy41dmOuKjNtOfujc4BzIhQs&s=7C0UEua9fFJk8x_ktluIxZ3TtMq16TNVHrYUYnMC8Jo&e=
