[gdal-dev] How can I track down autotest python error?
    David Adler
    dadler at adtechgeospatial.com
    Mon Jan  4 10:32:33 PST 2016
I'm getting:
GDAL:
GDALOpen(DB2ODBC:DB2:database=samp105;DSN=SAMP105A;tables=TEST.ZIPPOINT,
this=004995C0) succeeds as DB2ODBC.
GTiff: Reopen with strip chop enabled
GDAL: GDALOpen(..\gcore\data/cfloat64.tif, this=0485BEC8) succeeds as GTiff.
ODBC: SQLDisconnect()
GDAL:
GDALClose(DB2ODBC:DB2:database=samp105;DSN=SAMP105A;tables=TEST.ZIPPOINT, this=004995C0)
GDAL: GDALClose(..\gcore\data/cfloat64.tif, this=0485BEC8)
   File "../pymod\gdaltest_python2.py", line 42, in run_func
     result = func()
   File "ogr_db2r.py", line 278, in ogr_db2_CopyRaster1
     new_ds = ogrtest.db2_drv.CreateCopy(
'DB2ODBC:database=samp105;DSN=SAMP105A', src_ds )
   File
"C:\Python27\lib\site-packages\gdal-2.1.0-py2.7-win32.egg\osgeo\ogr.py",
line 363, in <lambda>
     __getattr__ = lambda self, name: _swig_getattr(self, Driver, name)
   File
line 57, in _swig_getattr
     raise AttributeError(name)
AttributeError: CreateCopy
GDAL: In GDALDestroy - unloading GDAL shared library.
def ogr_db2_CopyRaster1():
     if ogrtest.db2_drv is None:
         return 'skip'
     ds = ogr.Open(ogrtest.db2_test_server)
     if ds is None:
         return 'fail'
     src_ds = gdal.Open( '..\gcore\data/cfloat64.tif' )
I'm guessing this is from CreateCopy. There is no other obvious error
indication.
This works fine from gdal_translate.
Any suggestions?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160104/9df8dddc/attachment.html>
